Calendly has built integrations with the following video conferencing platforms:
- Zoom
- Google Meet
- Microsoft Teams
- GoTo Meeting
- Webex
Once connected, Calendly will automatically generate video conferencing details when someone books with you. You and your invitee will also receive details via confirmation email and calendar event.
If you use a video conferencing platform that isn't listed above, follow the steps in How to use other video conferencing options.
Let your invitee choose how to meet
For one-on-one event types, you can connect multiple video conferencing platforms and let your invitee choose their preferred way to meet.
How to schedule a meeting with video conferencing
In this article:
Step 1: Connect your Zoom account
- Visit your Integrations page and select Zoom.
- Select Connect Zoom.
- Sign in to your Zoom account.
- Select Authorize to let Calendly access your Zoom account. Note: If you see info about pre-approving, view Pre-approving Zoom.
Step 2: Select Zoom as your location
Once you've connected, you'll be redirected to Calendly. You'll see a message prompting you to set Zoom as your location for your event types. To do so, follow the steps for the relevant event type:
- Personal event type (one-on-one or group)
- One-off meeting
- Team event type (collective or round robin)
To use Zoom for a personal event type:
- From your Home page, select the event type you want to use Zoom with.
- Select Event details
- From Location, select Zoom.
Tip: For one-on-one event types, you can select add a location option to give your invitee multiple locations to choose from. - Select Save & Close.
- Repeat these steps for each event type you'd like to use Zoom with.
To use Zoom for a one-off meeting:
- Follow the steps to set up a one-off meeting.
- Under Location, select Zoom:
To use Zoom for a team event type:
- From your Home page, select the round robin or collective event type you want to use Zoom with.
- Select Event details.
- For round robin events:
1. Under Location, select Zoom for the team members who'd like to schedule with Zoom. Note: The team member must individually connect and authenticate their Zoom account (Step 1: Connect your Zoom account) before they can schedule with Zoom. An admin cannot connect on their behalf. -
For collective events:
1. Select one Zoom organizer. As the Zoom organizer, your Zoom account will be used to host the meeting. For more details, view Choose your Zoom organizer for a collective event.
2. Select Save & Close.
Step 3: Meet over Zoom
After your invitee books, you and your invitee will receive Zoom details via confirmation email and calendar event. The meeting will also show in your Zoom account under Upcoming Meetings.
Tip: You can customize your Zoom settings to enforce a Personal Meeting ID, require passcodes, adjust dial-in numbers, and more. View more in Getting started with Zoom.
In this article:
- Step 1: Connect your Google calendar
- Step 2: Select Google Meet as your location
- Step 3: Meet with Google Meet
To schedule with Google Meet, you'll need to connect your Google calendar and set it as your Add to calendar, outlined in the following steps. If you've already done so, skip to Step 2.
- In Calendly, navigate to your Calendar Connections page.
- Select + Add Calendar Account.
- Next to Google Calendar, select Connect.
- Sign in to your Google account you'd like to connect.
- Select Allow, so Calendly can see when you're available and add events to your calendar.
- Under Add to calendar, make sure your Google Calendar is selected. Your Google Calendar must be marked as the Add to calendar in order to host meetings over Google Meet. To change the Add to calendar, select Edit.
To set Google as your location for your event types, follow the steps for the relevant event type:
- One-off meeting
To use Google Meet for a personal event:
- From your Home page, select the event type you want to use Google Meet with.
- From Location, select Google Meet.
Tip: If you'd like to offer choices to your invitee, you can select add a location option. Your invitee can choose between meeting via Google Meet, Zoom, or a phone call, for example. - Select Save & Close.
- Repeat these steps for each event type you'd like to use Google Meet with.
To use Google Meet for a one-off meeting:
- Under Location select All options.
- Select Google Meet.
To use Google Meet for a team event type:
- From your Home page, select the round robin or collective event type you want to use Google Meet with.
Select Google Meet as the location for the team members who'd like to schedule with Google Meet. Note: the team member must individually complete Step 1: Connect your Google calendar before they can schedule with Google Meet. An admin cannot connect on their behalf. -
For collective events, decide which account hosts the Google Meet session:
1. Expand Notifications and Cancellation Policy.
2. Under Calendar Invitations, you'll see who is hosting under Sending from. If you'd like to change the user, select change.
3. Select Save & Close.
After your invitee books, you and your invitee will receive Google Meet details via confirmation email and calendar event.
In this article:
Step 1: Connect your Teams account
- If you've connected your Office 365 calendar as your Add to calendar, Calendly will automatically detect the Teams account associated with your calendar. To complete Teams setup, skip to Step 2: Select Teams as your location.
- If you're not using your Office 365 calendar as an Add to calendar, you can connect a Teams account with these steps:
- Visit your Integrations page and select Microsoft Teams Conferencing.
- Select Integrate Now.
- Sign in to your Microsoft account.
- Select Accept to let Calendly access your Teams account.
- Once accepted, you'll be redirected to Calendly, and you'll see a pop-up confirming you've connected.
To schedule with Teams for a specific event type, follow the steps for the relevant event type:
- One-off meeting
To use Teams for a personal event:
- From your Home page, select the event type you want to use Teams with.
- From Location, select Teams.
Tip: If you'd like to offer choices to your invitee, you can select add a location option. Your invitee can choose between meeting via Teams, Zoom, or a phone call, for example. - Select Save & Close.
Repeat these steps for each event type you'd like to use Teams with.
To use Teams for a one-off meeting:
- Under Location, select All options.
- Select Microsoft Teams.
To use Teams for a team event type:
- From your Home page, select the round robin or collective event type you want to use Teams with.
Select Teams as the location for the team members who'd like to schedule with Teams. Note: the team member must individually complete Step 1: Connect your Teams account before they can schedule with Teams. An admin or owner cannot connect on their behalf. -
You can decide which account hosts the Teams session.
Step 3: Meet with Teams
After your invitee books, you and your invitee will receive Teams details via confirmation email and calendar event.
Tip: If your invitee doesn't have a Teams account, they can choose to join the meeting by selecting Continue on this browser.
In this article:
- Step 1: Connect your GoTo Meeting account
- Step 2: Select GoTo Meeting as your location
- Step 3: Meet with GoTo Meeting
- Visit your Integrations page and select GoTo Meeting.
- Select Connect GoTo Meeting.
- Sign in to your GoTo Meeting account.
- Select Allow to let Calendly access your GoTo Meeting account.
Once you've connected, you'll be redirected to Calendly. You'll see a message prompting you to set GoTo Meeting as your location for your event types. To do so, follow the steps for the relevant event type:
- One-off meeting
To use GoTo Meeting for a personal event type:
- From your Home page, select the event type you want to use GoTo Meeting with.
- From Location, select All options.
- Select GoTo Meeting.
Tip: If you'd like to offer choices to your invitee, you can select add a location option. Your invitee can choose between meeting via GoTo Meeting, Google Meet, or a phone call, for example. - Select Save & Close.
- Repeat these steps for each event type you'd like to use GoTo Meeting with.
To use GoTo Meeting for a one-off meeting:
To use GoTo Meeting for a team event type:
- From your Home page, select the round robin or collective event type you want to use GoTo Meeting with.
Under Location, select GoTo Meeting for the team member who'd like to schedule with GoTo Meeting. Note: the team member must complete Step 1: Connect your GoTo Meeting account before they can schedule with GoTo Meeting. An admin or owner cannot connect on their behalf. - For collective events:
Select one GoTo Meeting organizer. As the GoTo Meeting organizer, your GoTo Meeting account will be used to host the meeting. You can select a different GoTo Meeting organizer, as long as the other user has connected their GoTo Meeting account to Calendly.
Step 3: Meet over GoTo Meeting
After your invitee books, you and your invitee will receive GoTo Meeting details via confirmation email and calendar event.
The meeting will also appear in your GoTo Meeting account.
In this article:
Step 1: Connect your Webex account
- Visit your Integrations page and select Webex.
- Select Connect Webex.
- Sign in to your Webex account.
- Select Accept to let Calendly access your Webex account.
Note: If you check the Only ask when requesting new permissions, then you will not see this message again when reconnecting.
Step 2: Select Webex as your location
Once you've connected, you'll be redirected to Calendly. You'll see a message prompting you to set Webex as your location for your event types. To do so, follow the steps for the relevant event type:
- One-off meeting
To use Webex for a personal event type:
- From your Home page, select the event type you want to use Webex with.
- From Location, select Webex.
- Repeat these steps for each event type you'd like to use Webex with.
To use Webex for a one-off meeting:
- Select Webex.
To use Webex for a team event type:
- From your Home page, select the round robin or collective event type you want to use Webex with.
1. Under Location, select Webex for each team member who'd like to schedule with Webex.
Note: The team member must complete Step 1: Connect your Webex account before they can schedule with Webex. An admin or owner cannot connect on their behalf. -
1. Under Location, select Webex.
2. Select the Webex organizer.
Note: As the Webex organizer, your Webex account will be used to host the meeting. You can change the Webex organizer later, as long as the other user has connected their Webex account to Calendly.
Step 3: Meet with Webex
After your invitee books, you and your invitee will receive Webex details via confirmation email and calendar event. In your meeting details, Calendly will automatically generate a Webex URL and a SIP email address (for video systems):
If you have a paid Webex account, your meeting details will also include a US dial-in number and a URL to find your local number (for international invitees).
You can also find the meeting details in your Calendly account, under Scheduled Events, or in your Webex account, under Meetings.
