IN THIS ARTICLE:
I'm unavailable when I should be free
You can use your Admin view to determine why your unavailable time slots are blocked. There are two common reasons you may appear unavailable on Calendly when you should be free:
- Your calendar may already have a "busy" event at that time
- A setting within your event type may be blocking your availability
Log in to your account and view any of your live event type pages. By default, you’ll see the public display of your availability shown to invitees. Locate the toolbar at the top of the page and click View as invitee. Update the setting to see an admin view of your page. Selecting a date will reveal any blocked time slots and the reason they’re unavailable.
Label | Why the time slot is unavailable |
PAST |
This time slot is in the past and can no longer be booked |
DAYMAX |
A daily limit has been set for this event type, and the limit has been reached |
GROUP |
This group event has reached its maximum number of attendees |
TOOSOON |
This time slot is outside of the event type's minimum scheduling notice |
RANGE |
This time slot is outside of the date range that has been set for this event type |
EVENT |
Someone has already scheduled this type of event during this time slot |
OVERLAP |
This time slot overlaps with another Calendly event that has been scheduled |
BUFFER |
You or your team members have a buffer setting that blocks this time slot Team members' names and conflicting buffer settings listed |
CALENDAR |
This time slot overlaps with a busy event in your connected calendar or one of your team members' Team members with "busy" calendar events listed |
NOCAL |
Calendly is unable to connect to your calendar or one of your team members' Team members whose calendars aren't connected listed |
UNFAIR | Only applies to round robin event types set to optimize for equal distribution The only available team members have received too many meetings. This time slot will become available again when events are scheduled with other users and the distribution of meetings becomes equal. Current distribution of meetings per team member listed |
I'm free when I should be unavailable
To find out why you are being shown as available when you should be busy, visit your connected calendar and take a closer look at the specific time slots in question. Be sure to check the same calendar(s) you have asked Calendly to check for conflicts.
Outlook users may notice that Calendly shows you as available during events labeled Tentative. Visit your Calendar Connection page and click Edit in the Check for conflicts section to update this setting.
All-day and multi-day events may be automatically set as free in your connected calendar. Prevent meetings from being scheduled by manually setting the status of all-day and multi-day events to busy.
Connected calendar event status
When events in your calendar are set to busy, Calendly assumes you're unavailable at those times and prevents new events from being scheduled. Changing an event's status from busy to free will allow new events to be scheduled during this time.
To allow invitees to schedule with you during an event on your connected calendar, simply update that event's status from busy to free. Calendly does not read free events as conflicts.
Any events scheduled through your Calendly page will always be seen as conflicts until you cancel or reschedule them from the Scheduled Events tab on your Home page.
