Beta
We've improved availability management and the event type editor, now in public beta for select users. If you're in the beta, check out this article to learn more.
Whether you're currently in the beta or not, you'll find the information you need to use Calendly's troubleshoot tool here in this article.
If invitees can’t see dates and times on your booking page, use the Troubleshoot Tool to identify why. It will display troubleshoot codes to let you know how to resolve it.
Are invitees scheduling time with you when you're busy? Read how to resolve this. |
Where to find the Troubleshoot tool
When you log into your Calendly account, the Troubleshoot tool can be accessed from your event type’s booking page.
Locate Troubleshoot codes
Navigate to your event’s booking page
Select Troubleshoot towards the bottom of the page
Select the date you are trying to resolve for
Identify the time and troubleshoot code listed below
Identify and resolve Troubleshoot codes
- What does it mean?
- A buffer applied on a Calendly meeting interferes with this time.
Buffer settings lock in when an event is scheduled. Changes made to the event type after the meeting has been scheduled will not retroactively apply to existing meetings.
Beta
If you're in the beta, you will be able to edit your buffers from the Meetings page in your account.
- How do you resolve it?
- To remove it, uncheck the active buffers from the event type settings and reschedule the event for the same date and time. Read the article.
- There is a "busy" event on your connected calendar at this time.
- Change calendar event status from "busy" to “free” or cancel the calendar event.
- You can view the calendar(s) Calendly is checking for conflicts from your Calendar settings page.
- The maximum allowed events per day for this type of event has been reached.
Edit the number of maximum allowed events per day for this type of event. Read the article.
Beta
If you're in the beta, you will be able to locate max meetings setting by opening your event type editor, selecting More options at the bottom, and expanding the Limits and buffers section.
- Event duration exceeds the available time period.
- Increase your availability settings or decrease the duration in your event type settings.
- A scheduled Calendly event of this event type is already scheduled at this time.
- Review and verify your scheduled meetings on your Meetings page.
- A Group event has reached its maximum number of attendees.
Change the max number of invitees from your Meetings page. Read the article.
- The holiday functionality in your availability settings is activated and the selected date is set as an observed holiday.
- You can edit your holiday settings at either the account level from your Availability page, or at the event type level within your event type's availability settings.
Beta
If you're in the beta, you will be able to manage your account holidays from the Holidays section of your Availability page, which you can locate in the left side menu of your home page.
- One of the event hosts for a collective event type are not available for that date/time.
For collective events, a date/time will only appear when all hosts assigned are available. Check info on which host is unavailable.
- Calendly is unable to connect to your calendar or a team member's calendar.
Ensure all calendars are connected in the Calendar settings page for you/your teams accounts.
Beta
If you're in the beta, you will be able to locate your calendar settings from the Availability page. You can find the Availability page in the left side menu of your home page.
- A Calendly meeting is already scheduled at this time.
You can review what events have been scheduled from your Meetings page.
Date & time is in the past and can no longer be booked.
- Select a date and time that is not in the past.
- Date is outside of the event type's set available date range.
Edit the date range section in the event type settings.
Beta
If you're in the beta, you will be able to locate your date range settings by opening your event type editor and expanding the Availability section. The date range settings will be at the top of this section.
- Time is reserved for a One-off Meeting or poll.
Schedule pending meetings for this time slot or clear reserved times from the Pending section of the Meetings page.
- No hosts assigned to the round robin event type are available.
Verify distributions settings are correct or change availability settings for team members who could take this meeting.
- Verify calendar and availability settings for hosts who are listed as unavailable who should be free.
- Date/time falls outside of the minimum scheduling notice restriction.
Change this setting within your event settings.
Beta
If you're in the beta, you will be able to locate your minimum notice setting by opening your event type editor and expanding the Availability section. The minimum notice setting will be at the top of this section.
- For round robin event types, this means that the only available team members for this date/time have too many meetings scheduled to allow for another.
Review your distributions settings or change the availability settings for other team members who could take this meeting.
- Learn more about round robin distribution settings.
Frequently asked questions
How does daylight savings time (DST) impact my availability?
Calendly will detect and display correct meeting times even during DST. However, while the time is correct, the labels for the time zone will not change based on observing DST.
For example, if an invitee scheduled to meet on the Monday after DST at 10AM, the meeting time will still display as 10AM.
I changed the event status on my calendar from busy to free. Why is my availability not showing up as free?
