How to troubleshoot unavailable hours
If your invitees can’t see dates and times that should be available, the Troubleshoot Tool can help you find out why.
This guide walks you through how to find and use the tool and what each troubleshoot code means—so you can quickly fix availability issues.
Image  Are invitees scheduling time with you when you're busy? Learn how to resolve this.
Step 1 – Access the Troubleshoot Tool
You can use the Troubleshoot Tool from your event type’s booking page or its preview.
To get started:
  1. Log into your Calendly account.
  2. Open your event type’s live booking page or preview.
  3. Scroll to the bottom and select wrench-icon.png Troubleshoot.
Step 2 – Use the Troubleshoot Tool
Once you open the tool:
  1. Choose the date you’re troubleshooting.
  2. If no available times are showing, go to the Availability section of your event type to review your settings.
  3. Review the troubleshoot code and the time it applies to.
Step 3 – Understand and Fix Troubleshoot Codes
Each code gives you a reason why time slots may be unavailable. Here’s what they mean and how to fix them.
BUFFER
  • What does it mean?
    • A buffer applied on a Calendly meeting interferes with this time.
    • Buffer settings lock in when an event is scheduled. Changes made to the event type after the meeting has been scheduled will not retroactively apply to existing meetings.
  • How do you resolve it?
CALENDAR
    • There is a "busy" event on your connected calendar at this time.
    • The "details" dropdown in troubleshooting mode will show the connected calendar where the event is present.
    • Review calendars & sub-calendars in the Calendars to check for conflicts section of your Calendar settings.
    • Change the conflicting calendar event status from busy to free or cancel the calendar event.
    • Ensure any all-day events on your personal calendar/sub-calendars for that date/time are set to free.
    • Allow Calendly to schedule over existing meetings.
DAYMAX
    • You've hit the daily, weekly, or monthly limit for this event type.
    • Round Robin DAYMAX: Round Robin events do not function on a per person limitation, but rather a limitation per event type.
      • (Ex. 6 team members assigned with a DAYMAX of 1, that event gets scheduled for Monday at 4pm, that event type will no longer be available for that day. Even if the other 5 team members are available.)
    • Edit the number of maximum allowed events per day/week/month for this type of event.
    • Locate The Max meetings setting by opening your event type editor, selecting More options at the bottom, and expanding the Limits and buffers section.
DURATION
    • Your event is too long for the available window.
    • For example: You have an event that is 2 hours long, but only have availability from 9am-10am (one hour). There would not be enough time available for a 2 hour long event to take place.
    • Shorten the event or increase your available hours.
EVENT
GROUP
    • A Group event has reached its attendee limit.
    • Change the max number of invitees from your Meetings page.
      Important note:
      Event settings lock in at the time of scheduling. Changing the max number of invitees in your event type settings will not change events that have already been scheduled. To change max invitees for an event that has already been scheduled, you can do so from the Meetings page.
HOLIDAY
    • The date is marked as a holiday on your Availability page.
HOST
    • For collective events, a date/time will only appear when all hosts assigned are available.
NOCAL
OVERLAP
PAST
    • The selected time is in the past.
    • Choose a future date and time.
RANGE
    • The date is outside of the event type's set available date range.
    • Edit the date range section in the event type settings.
    • You will be able to locate your date range settings by opening your event type editor and expanding the Availability section. The date range settings will be at the top of this section.
NOTE: To add Saturdays & Sundays to your availability, assign calendar days and not weekdays to your event.
RESERVED
    • Schedule pending meetings for this time slot or clear reserved times from the Pending section of the Meetings page.
      NOTE: Delays can occur when removing reserved times from your connected calendar.
ROUNDROBIN
TOOSOON
    • The time is too soon based on your notice requirements
    • Date/time falls outside of the minimum scheduling notice restriction.
UNFAIR
    • For Round Robin event types set to distribute evenly, available team members have too many meetings.
FAQs
Why is availability not showing up after I set calendar events to "free"?
Calendly blocks times for events it books—even if you change their status to "free" in your calendar. To open that time, cancel or reschedule the event from your Meetings page, or adjust your Free/busy rules.
Does daylight saving time (DST) affect my availability?
Calendly automatically adjusts for DST. Meeting times remain correct, but the time zone label may not reflect the change.
