How to troubleshoot the Outlook plug-in
Follow these steps to fix issues with the Outlook Plug-In for desktops when encountering unexpected behaviors.
Are you troubleshooting the Outlook plug-in or Outlook add-in?
The Outlook plug-in connects Calendly directly to your Outlook calendar. It to check for conflicts and adds events. This is separate from the Outlook add-in, which allows you to access your scheduling links or create a customized invitation directly from your Outlook toolbar. It does need to be installed separately. For more information on the Outlook add-in, check out How to install the Calendly Outlook add-in.
Troubleshooting the plug-in
Step 1 – Check your system requirements
You'll need a PC with Outlook 2007 or later and Windows XP or newer.
If you use a web-based Microsoft calendar such as Outlook.com, Office 365, or Exchange, we recommend connecting that calendar directly from your Calendar settings page. For more information on how to connect your calendar with Calendly, check out Connecting your calendar.
Step 2 – Check your calendar settings page
Check to make sure your plug-in is connected. If your Outlook plug-in is not connected, check out How to install the Outlook plug-in for instructions on how to install and connect your Outlook plug-in to Calendly.
Step 3 – Check your plug-in version and last sync date
To fix most issues, make sure you are running the most up-to-date version of the Outlook plug-in (Version: 174). You can confirm this at any time by navigating to your Calendar settings page or by contacting our support team
If you're not running the most up to date version, check out How to install the Outlook plug-in for instructions on how to re-install and connect your Outlook plug-in to Calendly.
Step 4 – Make sure you're only running one version of the Outlook plug-in
In order for the Outlook plug-in to properly sync with Calendly, you should only run one instance of the Outlook plug-in per Calendly user.
Step 5 – Check that your Outlook plug-in is your system tray icon
The Outlook plug-in will only sync when it is running in the background and your computer is connected to the internet. Any changes made while your computer is off and the plug-in is disconnected will only update once your device is back on. To check if your Outlook plug-in is running:
  1. Select the upwards-facing arrow in your Windows taskbar to Show hidden icons.
  2. From there, look for an item listed with the Calendly logo.
  3. If you do not see an instance of the Outlook plug-in running in your taskbar, use your PC's search bar to search for, and open the Calendly Plugin for Outlook.calendlyforoutlook.gif
  4. If you do not see the Calendly Plugin for Outlook app within your search bar, the Outlook plug-in is not installed on your device. For more information on how to install the Outlook plug-in, check out How to install the Outlook plug-in.
Step 6 – Check your Outlook plug-in advanced settings
1. Set Sync to Realtime
Set your sync to "Realtime" so Calendly can update your Outlook calendar right away. To set your Outlook plug-in sync to realtime:
  1. Open the Outlook plug-in via the taskbar in Windows (or by searching for the Calendly Plugin for Outlook in your Windows search).
  2. Select Settings
  3. Select Advanced in the bottom left corner of the Settings window.
  4. Select Realtime under Auto-Sync within the Advanced Settings window.
  5. Select OK to confirm your changes within the Advanced Settings window.
  6. Select Save to save changes made within your Outlook plug-in Settings.
2. Select Re-read
  2. Select Settings
  4. Check Reread Outlook and Reread Calendly under the section titled Logging.
3. Disable MAPI
  2. Press CTRL+SHIFT+U to open the Special Settings Screen.
  3. Check Disable MAPI to the right of Disable MAPI DLL for Outlook.
  4. Select OK to confirm your changes within the Advanced Settings window.
