Calendly’s Outlook add-in makes it easy to schedule meetings without ever leaving your inbox. From your Outlook toolbar, you can access your scheduling links or create a customized invitation for your invitee to choose from.
For example, you can:
- Access personal and shared event types
- Share your Calendly links
- Create meeting polls
- Create one-off meetings
The Outlook add-in is different from the Outlook plug-in. The plug-in connects Calendly to your Outlook calendar to check for conflicts and add events, and it must be installed separately. See our help center article on the Outlook plug-in for more details.
Install the add-in
Office 365 or Outlook for Mac
- Click here to access the Calendly for Outlook in the AppSource store.
Click Get it now.
Outlook for Windows, Outlook 2019, or Outlook 2016
In Outlook, go to the navigation bar and select More Apps > Add apps.
- Search for Calendly for Outlook.
- Select Add.
If you have an older version of the add-in, you will need to log in to your Microsoft account and uninstall your existing version of the Calendly Outlook add-in before installing the newest version. To learn more about using add-ins in Outlook, see Microsoft's support article.
Accessing the add-in
Once installed, you can access the Calendly Outlook add-in from your Outlook mailbox.
- Open Outlook and start a new email or reply to an existing one.
- Click the Calendly icon in the Outlook toolbar.
- Log in to Calendly. The add-in will open on the right side of Outlook.
Uninstall the add-in
If you no longer need the Calendly Outlook add-in or want to reinstall it, you can remove it using Outlook’s Add-ins manager. For more information, see Microsoft’s support article on using add-ins.
From Outlook (desktop)
- In Outlook, go to File > Manage Add-ins or Manage Apps.
- In the Add-ins manager, find Calendly for Outlook and select Remove.
From Outlook on the web
- Go to your Outlook add-ins menu.
- Under My add-ins, find Calendly for Outlook.
- Select More actions, then choose Remove.
