Outlook Desktop Plug-in
Calendly_Outlook_Integration_OG.webp The Outlook Plug-In, sometimes called the Calendly Plug-in for Outlook or the Outlook Desktop Plug-In, is a Windows application that connects your local Outlook desktop calendar to your Calendly account.
If you use a web-based Microsoft calendar, like Outlook.com, Office 365, or Exchange, we recommend connecting your calendar directly from your Calendar Connections page, instead of installing the plug-in. However, if you cannot use a web-based version of your Microsoft calendar, you can use the Outlook Plug-In to connect to your local Outlook calendar on your computer.  plugin_.png
calendly_shapes19.png Related Outlook Plug-in Articles
Article Description
Installing the Outlook Desktop Plug-in Overview of installing and syncing the plug-in to your computer.
Troubleshooting the Outlook Plug-in Steps to take for troubleshooting common issues with the plug-in.
Outlook Plug-in FAQ Frequently-asked questions about the plug-in.
Uninstalling the Outlook Desktop Plug-in Overview of uninstalling the plug-in from your computer.
