If you no longer need the Calendly Outlook Plug-in or are having issues, follow this guide to uninstall it from your computer easily.
- If you're experiencing an issue with the plug-in, you can troubleshoot common issues with the help of Troubleshooting the Outlook plug-in.
- If you plan to reinstall the plug-in later, first disconnect your calendar integration:
- Log into your Calendly account.
- Navigate to your Integrations page.
- Find your Outlook Plug-in connection and select the X to disconnect.
Uninstall the plug-in
- From the Windows Settings menu, select System.
- Under System on the left-hand side, select Apps & features and locate the Calendly Plugin for Outlook on the right-hand side.
- Select Uninstall.
- At "Do you want to view troubleshooting help before uninstalling?":
- Selecting Yes will direct you to our Help Center.
- Selecting No will allow you to continue the uninstall process.
- Select Uninstall to uninstall the plug-in.
- Select Ok.
