With Calendly's Gong browser integration, you can add a scheduling button to Gong’s email compose window. This lets you quickly share your availability and access events without switching between apps. You can also create a Meeting Poll or schedule a One-off Meeting.
To get started, ensure you have access to Gong Engage and have downloaded the Calendly browser extension.
How to turn on or off the Gong integration
From the Calendly browser extension:
- Select the Calendly logo in the top left corner of the extension.
- From the drop-down menu, choose Settings.
- Under Extension integrations, toggle Gong on or off.
Using the Gong extension
From the Gong Engage email composer:
- Find the Calendly button in the bottom-left corner and select it.
- Choose your event type, or select Meeting Poll or One-off Meeting.
When sharing your event type, choose how you want to share your link. You can either insert the link or add available times directly into the email.
