Learn how to clone an existing event type in the Calendly mobile app to quickly reuse your scheduling settings and preferences.
If you’ve already set up an event type and want to reuse its settings, you can easily clone it in the Calendly mobile app. This helps you save time by copying your preferences without starting from scratch.
Clone an Event Type on Mobile
Follow these steps to create a copy of an existing event type:
- From the mobile home page, select the event type you want to clone.
- Tap View event type details.
- Scroll to the bottom of the screen.
- Tap Clone this event type.
- Calendly creates a copy titled: Original Title (clone).
- Tap the title to rename or update the event as needed.
