Before you begin…
When you change your scheduling page link, the previous link will no longer direct your invitees to your scheduling page.
From the mobile homepage, select the event type you’d like to edit.
Under Name and duration, select the event type name.
Under Customize your booking page link, select the existing link and select the "x" icon to delete the current text.
Begin type to add new text.
Select Done to save your changes.
