You can embed your Calendly page so visitors can schedule time without leaving your site.
Step 1 – Choose what you want to embed
Calendly offers two embed options:
Landing page embed – Shows all active personal or team event types.
- Go to the Scheduling page.
- (Optional) Open the My Calendly dropdown to switch to another user or team page.
- Select the
three dots in the top-right corner, then select Add to website.
Booking page embed – Show just one event type.
- Find the event type, select the
three dots in the event card, then select Add to website.
Step 2 – Copy your embed code
Choose how you want Calendly to appear on your site:
- Inline embed – Displays directly on your page.
- Popup widget – Adds a floating button to open your scheduling page.
- Popup text – Adds a clickable link that opens your scheduling page.
Then:
- Select Continue.
- (Optional) Change your settings:
- Hide your photo
- Hide event details
- Remove the cookie banner
- Customize colors (paid feature)
- Select Copy Code.
Paste the code into your website’s HTML.
Step 3 – Select your website provider
Choose your provider for specific embed steps:
Need more help?
Check out these helpful resources:
