How to add Calendly to your Squarespace site
Before you begin...
  • Make sure you have a Squarespace Business Plan.
  • Keep Calendly and Squarespace open in a separate browser window or tab, for easier setup.
  • Note that adding Calendly may affect your site's appearance.
To add Calendly to your Squarespace site
  1. Sign in to Squarespace.
  2. Navigate to the page you would like to edit.
  3. Hover over page content and select Edit.
  4. Add a code block. To do so, follow the steps in Squarespace's Add a code block.
  5. In Calendly, retrieve your embed code by following the steps in Embedding Calendly on your site.
  6. In Squarespace, paste the code snippet you copied from Calendly.
  7. Select Apply.
If your embed code does not display after completing the above steps, follow these additional steps below:
  1. Go to Settings.
  2. Select Advanced.
  3. Under Code injection, in the header section, paste:
    <script type="test/javascript" src="http://calendly.com/assets/external/calendly-squarespace.js"></script>
  4. Select Save.
Note:
  • If you are experiencing performance issues with your embed, you may need to disable Ajax. Read more about this issue, or contact us for assistance.
  • Whereas older Squarespace themes supported buttons with Javascript, Squarespace 7.1 does not support buttons with Javascript.
Was this article helpful?
108 out of 181 found this helpful
