You can edit your Zoom account settings to automatically enable or disable one tap mobile numbers and dial-in numbers when your invitees schedule.
To use one tap mobile and dial-in numbers
One tap mobile and dial-in numbers will automatically show if your Zoom account uses Telephone or Telephone and Computer Audio as your audio type. If your Zoom account is set to only use Computer Audio, no dial-in information will show. To edit your audio type, view Zoom's Enabling Audio Type.
To select dial-in numbers by country and region
To edit which countries and regions are presented as default dial-in options, view Zoom's Specifying Global Dial-in Countries/Regions.
To use or remove the find your local number option
To remove the Find your local number option from your Zoom details, view Zoom's Showing the international numbers link on invitation email.
To remove dial-in numbers entirely
