Use the Location section of your event type to choose where your meeting will take place. You can meet in person, by phone, over video, at a custom location, or let your invitee provide the location.
Set the location
- Go to the Scheduling page and select the event type you want to edit.
- Expand the Location section.
- Choose a location from the list:
- Video conferencing - Connect a supported video tool: Zoom, Google Meet, Microsoft Teams, Webex, or GoTo Meeting.
- Phone call - Require the invitee’s phone number to help reduce no-shows, or provide your phone number after booking.
- In-person - Enter the meeting address and additional notes.
- Custom - Enter the location details and choose whether to display them on the booking page or only after booking.
- Ask invitee - Add a location question for invitees to complete on the booking page.
- When you're finished, select Save changes.
If you use a video tool that Calendly doesn’t integrate with, paste a static link under Custom. See How to use other video conferencing options.
Add multiple location options
For one-on-one event types, you can offer multiple location options for invitees to choose from.
- Select + Add location.
- Choose another location type.
- Repeat as needed.
When you're done, select Save changes, or move to the next section of your event type.
You cannot assign different days or times to different locations within a single event type. To do this, you will need to create separate event types.
After an invitee books
Calendly will share the location details in:
- The confirmation page
- The calendar event
- Email or text notifications
Need to change a scheduled meeting’s location?
Once a meeting is booked, its settings are locked. To change the location:
- Update the event type's Location section.
- Go to your Meetings page.
- Find the meeting.
- Reschedule it for the same time and date with the new location.
