Add Calendly to Chrome for quick access to your scheduling links, one-off meetings, and more—from your browser toolbar.
- In Calendly, go to the Integrations & Apps page.
- Search for Calendly for Chrome and select it.
- You’ll be taken to the Chrome Web Store.
- Select Add to Chrome.
- When prompted, select Add extension to confirm.
Once the extension is added, you’ll see a confirmation message.
View the Chrome extension
After installing the Calendly for Chrome extension, it will appear as a floating button on web pages that can utilize it.
Because this button will appear on its own, you do not need to pin the extension to your toolbar in order to utilize it.
If you wish to pin the extension, follow the steps below:
- Open a new tab or window in your web browser and then select the jigsaw puzzle icon
at the top of your browser window.
- Select the jigsaw puzzle icon
and your Chrome extensions menu will open.
- Locate the Calendly extension under that menu and select the pushpin icon
to ensure that the Calendly for Chrome extension is added to your browser toolbar.
- Once the extension is added to your Chrome browser toolbar, you will see the Calendly logo on that toolbar and you can select it at any time to access the Calendly for Chrome extension.
Gmail integration
After installing the extension, you can also use it in Gmail to quickly add event types, one-off meetings, or meeting polls to your email. Learn how to use the Calendly extension for Gmail.
