Use Calendly’s mobile app to choose a meeting location for your event type. This helps you manage your meetings while on the go.
First, connect your video conferencing tool on the Integrations & apps page.
To learn more, check out Schedule with video conferencing.
Set a meeting location
- From the mobile homepage, select the event type you want to edit.
- Tap Edit meeting type.
- Tap Location.
- If you are adding an additional location, tap + Add a location option.
- Choose your preferred location from the list.
- Tap Save.
Note for group events
For group event types, you can’t change the location after someone schedules it. To update the location, clone the event type and set a new location in the clone.
