How to set up SAML SSO with your identity provider
Use SAML single sign-on (SSO) to let users log in to Calendly with their identity provider. This makes signing in faster, more secure, and easier to manage.
For example, you can:
Calendly supports the SAML 2.0 protocol and works with most enterprise identity providers (IdPs). You can follow these steps for any IdP—even if it’s not listed above.
  • You must be a Calendly owner or admin.
  • Use the same email address in Calendly and your IdP.
  • Open Calendly and your IdP in two browser tabs for easier setup.
  • Calendly doesn’t support Just-in-Time (JIT) provisioning. Use SCIM instead to manage users.
Configure SAML SSO in Calendly
Enter your IdP info in Calendly
  1. In Calendly, go to Admin center > Login > Single sign-on.
  2. Under Step 1, enter the following info from your IdP:
    IdP setting Calendly field Required? Notes
    Issuer or Entity ID Entity ID Yes Also called “Issuer URL” or “Issuer ID”
    SSO URL Identity provider's SAML HTTP Request URL Yes Also called “Login URL” or “SAML 2.0 Endpoint”
    x.509 certificate X.509 certificate for SAML authentication Yes
    Must be in PEM format
  3. Choose Save & continue.
Configure your identity provider
Add these Calendly values in your IdP settings
IdP setting Value Required? Notes
Audience Calendly’s Audience URL Yes  May also be called “Entity ID”
ACS URL Calendly’s ACS URL Yes Also known as “Reply URL” or “Callback URL”
Recipient/Destination Calendly’s ACS URL Yes Some IdPs fill this in automatically
Request Binding urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST  Yes May be shown as “POST”
Default Relay State Calendly’s Default Relay State Yes if using IdP-initiated login Needed to log in from your IdP dashboard
Assertion Signature SHA256 Yes Required
Response Signature SHA256 No Optional
Encrypted Assertion Not supported No Calendly doesn't support this
Name ID User’s email address Yes Must match Calendly email
Name ID Format urn:oasis:names:tc:SAML:1.1:nameid-format:emailAddress or unspecified Yes
Use either option
Set attribute mappings
Add these exact attribute names in your IdP:
Name Required? Description
email  Yes User’s main email address
firstName  Yes User’s first name
lastName  Yes
User’s last name
Assign user access
Update your IdP rules so the right people can access Calendly.
Test the connection
  1. In Calendly, turn on Enable SSO for yourself.
  2. Select Test connection.
  • If the test works, you’ll see a success banner.
  • If it fails, check that:
    • The user’s IdP email matches their Calendly email.
    • The attributes in your IdP are mapped correctly.
Enforce SSO for your organization
  1. In your IdP, assign the Calendly app to all users.
  2. In Calendly, select Enforce SAML SSO for my organization, then choose Apply.
Note: This logs out everyone. They must sign in using SAML SSO. The org owner can still log in with their original method by choosing Log in using another method.
What’s next?
