As an account owner or admin, you can place members of your organization into groups.
You can use groups to:
segment users based on department, job function, or location
delegate control to 'group admins' to manage and report on their group
view scheduled events and activity by group
To create a group, view Create a group.
Group admins
Group admins can manage and report on members in their group, without needing full admin permissions to organization-level settings. In addition, group admins can manage their members without seeing or affecting other groups.
To create a group admin, view Change the role of a group member.
Note: A group can have multiple group admins, but they cannot be in more than one group at a time.
Group reporting
With group reporting, you can export a report to track:
- who has activated their account
- whose invitation is still pending
- the total number of events scheduled by a member since joining Calendly
- the day of the last meeting scheduled
- the total number of meetings scheduled in last 30 days
To export a group report, view Export a list of group members.
Create a group
Before you start...
- Only admins and owners can create groups.
- A user must be in an organization before you can add them to a group. Learn more about adding users to an organization.
From any Calendly page, select Account, Admin Management, then Groups.
Select Create new group, enter the Name of the group, and select Continue.
To add members, select Add members and enter the names of the group members.
Once all the members have been entered, select Add.
Change a group name
Locate the group you would like to edit. Use the search bar if your organization has a lot of groups.
Select the 3 dots to the right of the group and select Edit.
Select the pencil icon next to the group name.
Highlight the old group name and enter the new name of the group (up to 50 characters).
Select Save.
Delete a group
Locate the group you would like to delete. Use the search bar if your organization has a lot of groups.
Select the 3 dots to the right of the group.
Select Delete.
Note:
Only admins and owners can delete a group.
Once you delete a group, you cannot undo deletion.
Deleting a group will not remove the group members from the organization.
Members of a deleted group can be added to a new group after deletion.
Add a member to a group
Select the group you would like to edit. Use the search bar if your organization has a lot of groups.
Select Add members and enter the name or email of the member you’d like to add.
Select Add.
Note: Organization admins and owners can edit groups without being assigned as a group admin.
Select the check box(es) next to the member(s) you’d like to edit.
Select Change role. Then, select the role you’d like to assign to the member(s):
Group members have no additional permissions.
Group admins can add or remove users from the group, change group member roles, and resend Calendly invites to group members.
Reassign a group member
A member can only belong to one group. Use these steps to remove a member from one group and assign them to a different group.
Select the check box next to the member you would like remove.
Select Remove from group.
Return to the list of groups by selecting Groups in the top left.
Select the group you’d like to assign this member to and select Add members.
Enter the name of the member, and select Add.
Account owners and account admins can use these steps to export a list of group members that includes information like:
who in the group has activated their account
who hasn't accepted the invitation to join Calendly
total events scheduled by a member since joining Calendly
the total meetings scheduled in last 30 days
Select Export members list to download a CSV file.
Remove a member from a group
