How to mark no-shows for meetings
Use Calendly’s no-show feature to mark whether someone attended a meeting.
If you're on the Standard plan or higher, you can use Workflows to send an email to no-shows to book a new time.
Mark an invitee as a no-show
  1. Go to your Meetings page.
  2. Find the meeting and open the Details.
  3. Select Mark no-show under the meeting details.
  4. Confirm the no-show.
Additional notes
  • Invitees marked as no-shows won’t receive follow-up emails—unless the Workflow is set to target no-shows specifically.
  • The No Show button appears only after the meeting’s scheduled start time.
  • No-show status is included in your Meetings CSV export.
  • You can undo a no-show if you change your mind.
  • For Group event types, you can mark each invitee as a no-show individually.
  • You can mark a no-show on mobile, web, or the extension.
