How to add a phone number to your account
Using Workflows, you can send text messages to yourself as the meeting host. These messages help you stay up to date on your meetings and receive reminders. To set up those host text messages, add and verify your phone number.
Add a phone number
  1. Select your profile picture in the top-right corner and choose All settings.
  2. Go to the Communication settings page.
  3. Enter your phone number and select Send verification code.
  4. Check your phone for a text message with a numeric code.
  5. Enter the verification code into the boxes.
After the code is confirmed, the page will refresh with your phone number saved. You can now select it when creating a Workflow to send a text to yourself as the host.
If you have another phone number, select Add another number and repeat these steps.
Remove a phone number
  3. Next to the phone number you want to remove, select the X.
  4. Confirm by selecting Yes, delete it.
