How to be notified on your phone when new meetings are booked or changed
Before you begin…
Only Calendly users that have downloaded the mobile app can utilize this notification feature. Download the app from the Apple Store or the Google Play Store and log in using your Calendly account information.
  1. From the mobile homepage, select the 3 line menu icon in the top left.
  2. Select Notifications.
  3. Tap the toggle button to turn on Push Notifications.
  4. Choose which type Event notifications you’d like on or off (New, Rescheduled, Canceled).
  5. Select Save.
If you’re still not receiving notifications, use the following procedure to learn what to do when you’re experiencing an issue with the mobile app.
Was this article helpful?
17 out of 28 found this helpful
