If you’re experiencing an issue, follow these steps:
Step 1: Is everything up to date?
Make sure you’re running the latest version of the Calendly app and that your phone operating system is up to date.
Step 2: Quit and reload the app
If everything is up to date, try quitting out of the app and reloading.
Step 3: Restart your device
If reloading the app didn’t help, try restarting your device.
Step 4: Check your internet connection
If restarting your device didn't help, check your internet connection or the strength of your mobile data connection.
Step 5: Uninstall and reinstall the app
If restarting your device and checking your internet connection didn’t help, try uninstalling the app:
iPhone and iPad
Locate the Calendly app, tap, and hold until it shakes or until a menu appears.
Select Remove App to uninstall.
Go to the Apple Store to reinstall the Calendly app and log in.
Android
Go to Settings. Then, Apps.
Select Calendly. Then, Uninstall.
Go to the Google Play Store to reinstall the Calendly app and log in.
Still having trouble? Contact support at support@calendly.com and we’ll be happy to assist you.
