Set up Workflows to automate email and text messages for meeting reminders and follow-ups. You can start with a template for a quick setup, or design a custom Workflow.
Create a Workflow
- Go to the Workflows page.
- Choose whether you want to use a template or create a custom Workflow.
To use a template:
- Choose a Workflow template from our library and click Use workflow.
To create a custom Workflow:
- Select Create your own workflow.
- In the When this happens section, choose a trigger and set the time for your Workflow.
- In the Do this section, choose an action, then select Next.
To use a template:
- In the Workflow name section, enter a name for your Workflow.
- Workflows are organized by chronological order and are unable to be arranged. We recommend using a naming system so they are sorted based on your preferences.
- In the Which event types will this apply to? section, choose your event types for this Workflow, then select Apply.
- In the Do this section, select Edit and customize your email or text message, then select Done.
- To insert variables that autofill meeting details:
- Place your cursor in your message, click Variables in the toolbar, and choose a variable from the list.
- It will automatically populate with the relevant information once the meeting is scheduled.
- (Optional) To include more actions in your Workflow, select Add Actions and repeat Step 3.
- After setting up your Workflow, select Save.
What's next?
Now that you've created a Workflow, explore additional ways to manage and customize your Workflows with these resources:
- How to edit, clone, or delete Workflows: Understand how to manage your existing Workflows.
- How to send Workflow emails from your Gmail or Outlook account: Set up your email account to send Workflow emails directly through Gmail or Outlook.
- Send text messages with Workflows: Discover the additional steps and settings required to set up automated text notifications with Workflows.
