This article explains how to edit, clone, or delete a Workflow using the three-dot menu next to each Workflow.
If you don't see the three-dot menu, contact your owner or admin to update your permissions or make changes to your Workflows.
Steps to manage a Workflow
- From your Calendly home page, select Workflows.
- Locate the Workflow you want to manage and click the three-dot menu next to it.
- Choose one of the following options:
- Edit: Make changes to the Workflow, then click Save.
- Clone: Create a copy of the Workflow, edit it as needed, and click Save.
- Delete: Confirm by selecting Continue.
