How to edit, clone, or delete Workflows
Edit, clone, or delete a Workflow using the three dots menu next to each Workflow.
If you don't see the menu, contact your admin to update your permissions or make changes to your Workflows.
Manage a Workflow
  1. Go to the Workflows page.
  2. Locate the Workflow you want to manage and select the three-dots-icon.png three dots next to it.
  3. In the menu, choose one of the following options:
    • Edit - Make changes to the Workflow, then select Save.
    • Clone - Create a copy of the Workflow, edit as needed, and select Save.
    • Delete - Remove the Workflow by selecting Continue.
