Invitations and confirmations
When invitees schedule with you, by default Calendly sends a confirmation email with a link your invitees can use to add the event to their calendars.
If you connect Calendly with a Google, Office 365, or Outlook.com calendar, Calendly can send an invitation from your calendar application that automatically adds the event to both your calendars.
If you change event details on your calendar, Calendly automatically updates your invitee's calendar accordingly.
Notes:
- If you connected Calendly to iCloud or the Outlook plug-in, or if you didn't connect a calendar at all, you aren't able to send Calendar Invitations (but you can still send email confirmations.)
- Calendly doesn't send calendar invitations for group events.
- If your invitee responds to a confirmation email, you'll receive the message at the email address that you use to log into your Calendly account.
- If your invitee responds to a calendar invitation, you'll receive the message at the email address associated with your connected calendar.
Hide your personal email (no-reply email address)
Normally Calendly sends invitee notifications using the email address that's associated with a calendar you connected to Calendly. You can choose to use a "no-reply email address" and hide your personal email; Calendly then uses "notifications@calendly.com" as return address on notifications. When the "no-reply email address" is in use, it will apply to invitee notifications (confirmations, reminders, and email follow-ups) for that specific event.
When messages are sent using a "no-reply" email address, a message appears at the bottom informing recipients that the email should not be used for a reply and is only intended for sending messages. If recipients do reply, the email is sent to an unmonitored email inbox and will not be received.
Reminder email invitee notifications
With an Essentials, Professional, Teams, and Enterprise account send one or more invitee notification emails and/or text messages to invitees days, hours, or minutes before the event starts. Calendly sends text invitee notifications from a Calendly number to the phone number your invitees provide during scheduling. Invitees can unsubscribe by replying "STOP".
Calendly Professional, Teams, and Enterprise subscribers can send unlimited text invitee notifications without additional charge.
Customize invitee notifications
Calendly Professional, Teams, and Enterprise subscribers can personalize email and text invitee notifications to change the title, subject, and message body. We provide a collection of variables you can use to insert values into the email that are specific to your invitee or the event. These values can come from the event details or from custom questions that invitees answer.
Follow-up email invitee notifications
Send customized follow-up email invitee notifications, minutes, hours, or days after the event ends. If you disable follow-up email invitee notifications, we'll immediately stop sending them.
Canceling events
If you cancel an event, Calendly automatically notifies your invitee. Add your cancellation policy to let invitees know if and when they can change events. Your policy will be included in any email invitee notifications your invitees receive.
If an event is set to email confirmations, the invitee will only receive an email cancellation if the host cancels the event. An invitee cancellation will not trigger an email.
Rescheduling events
Email invitee notifications, by default, include links that allow invitees to cancel or reschedule events. You can remove these links so invitees can't change an event.
See these procedures
To send calendar invitations
To send email confirmations
To personalize email and text messages
To send reminders
To send follow-up emails
To prevent cancellations or add your cancellation policy
To enable or disable calendar invitations
- From the Event Tab of your Home page, click the event.
- Expand the Notifications and Cancellation Policy section.
- Click Switch to Email Confirmations.
- (Calendly Professional, Teams, and Enterprise subscribers only) To personalize your invitation, see To personalize email and text messages.
- Click Save & Close.
To enable or disable email confirmations
- Select Switch to Calendar Invitations.
- Select Save & Close.
To personalize email and text notifications
Calendly Professional, Teams, and Enterprise users can use these steps to update:
- the subject of an email notification
- the body of an email notification or text message
- the dynamic variables in an email notification or text message
- the no-reply address in an email notification
- From the Event Tab of your Home page, select the event.
- To use a no-reply return address:
- In the Calendar Invitations section, select Switch to Email Confirmation.
- Select Use a no-reply email address at the bottom of the page.
- To personalize the message Title or Body:
- Select Personalize next to the type of notification you want to personalize.
- Adjust the message Title or Body.
- To add a dynamic variable:
- Select + Variables.
- Choose the dynamic variable(s) you'd like to use.
To enable or disable email or text reminders
- To send text reminders, at Text reminders click the button to turn them on or off.
- To send email reminders, at Email reminders click the button to turn them on or off.
- Click Personalize, then at Timing specify how many days, hours, or minutes before the event you want to send the reminder. To add additional reminders, click Add Another Reminder and enter the timing information.
- (Calendly Professional, Teams, and Enterprise subscribers only) To personalize your reminder message, see To personalize email and text messages.
To enable or disable follow-up emails
- At Email Follow-up click the button to turn them on or off.
- Click Personalize.
- To personalize your reminder message see To personalize email and text messages.
- At Timing specify how many days, hours, or minutes after the event you want the email sent.
To allow invitees to reschedule and cancel or add a cancellation policy
- Expand Show Cancellation Policy then click Include cancel and reschedule links in notifications.
- To add your cancellation policy, enter it at Cancellation Policy.
