How to set up two-factor authentication (2FA)
Add an extra layer of protection to your Calendly account by enabling two-factor authentication (2FA). When you sign in with your password, you'll be asked to enter a one-time code generated by your authenticator app, ensuring that only you can access your account.
  • Make sure you have access to your mobile phone when signing in to Calendly.
  • Each time you sign in, you'll need to enter a verification code along with your password.
  • Download and install an authentication app on your device. Calendly 2FA works with most time-based, one-time password (TOTP) apps, such as Authy or Google Authenticator.
How to enable 2FA
  1. From the Account settings drop-down menu, select Profile.
  2. Select Login preferences.
  3. Navigate to Two-factor authentication and toggle it On.
  4. Verify your password when prompted.
  5. Scan the QR code with your authenticator app.
  6. Enter the verification code from your authenticator app to complete the setup.
How to disable 2FA
  3. Navigate to Two-factor authentication and toggle it Off.
  4. Verify your password when prompted to confirm the change.
