How to set the location for your event type
In the Location section of your event type, choose how you want to host your meeting. You can meet:
  • In person
  • By phone
  • Over video
  • At a custom location
  • At a location your invitee provides
Set the location
  1. From your Scheduling page, select the event you want to edit.
  2. Open the Location section.
You can now choose one or more of the following:
In-person meeting
  1. Enter the address or meeting place.
  2. Want to add more details? Select + Add a note.
  3. Select Save changes.
Phone call
  1. Choose one:
    • Require invitee's phone number
    • Provide a phone number to invitees after they book
  2. Select Save changes.
Tip: Choose Require invitee's phone number to reduce no-shows. Calendly will add a phone number field to the booking page.
Video conferencing
To meet over video, first connect your video conferencing tool to Calendly.
Custom location
  1. Enter your custom location (this could be a static video link).
  2. Choose to show it:
    • On booking page
    • Only after booking confirmation
Tip: If you use a video tool that Calendly doesn’t integrate with, paste a static link here. See How to use other video conferencing options.
Invitee provides the location
  1. Select Ask invitee.
  2. Calendly will add a location field to the booking page.
Add multiple location options
To let invitees choose a location:
  1. Select + Add location.
  2. Choose another location type.
  3. Repeat as needed.
When you're done, select Save changes, or move to the next section of your event type.
You cannot assign different days or times to different locations within a single event type. To do this, you will need to create seperate event types.
After an invitee books
Calendly will share the location details in:
  • The confirmation page
  • The calendar event
  • Email or text notifications
Need to change a scheduled meeting’s location?
Once a meeting is booked, its settings are locked. To change the location:
  1. Update the event type's Location section.
  2. Go to your Meetings page.
  3. Find the meeting.
  4. Reschedule it for the same time and date with the new location.
