How to integrate Calendly with Salesforce
In this article, we'll go over how to get started with our Salesforce integration. From installing the package, what to expect from the package, customizing your package, and scheduling meetings from Salesforce, you’ll find it all here.
  • You must use Salesforce Enterprise edition or higher.
  • You must be a Salesforce Admin.
  • You don’t need to create a separate Salesforce integration user, but we recommend a dedicated integration user to make ongoing management easier.
What the package does
Calendly’s Salesforce integration can automatically create and update Salesforce records as invitees schedule meetings, send and store Calendly routing form responses in Salesforce, and send Calendly profile and managed event links to Salesforce mapped to the correct Salesforce user.  This allows you to enable merge fields for sharing the right person's Calendly link in automations/email templates.
As Calendly meetings are created or canceled, you can:
  • Create and update any Salesforce object
    • By default, the integration works with leads and events, but this is customizable
  • View upcoming Calendly events from your record’s open activities
  • Track canceled and rescheduled events for individual invitees
  • Report on activity sourced by Calendly
Calendly's Salesforce integration is designed to give you transparency and control. Installing the Calendly Salesforce integration adds Salesforce components to your org to support this functionality. For more details on default behavior, view Default behavior of the Salesforce package.
Integrate Calendly with Salesforce
Follow the steps below to install the Calendly package in your Salesforce instance and integrate your Salesforce account with Calendly. To test and customize your setup before going live, you can also connect your Salesforce sandbox.
  1. In Calendly, go to the Integrations & Apps page.
  2. Under Sales and CRM, select Salesforce.
  3. Select Connect Salesforce.
  4. Enter your Salesforce credentials, and select Log In.
    • Calendly does not use your Salesforce Client ID or Client Secret to directly access your Salesforce data.
  5. From the Salesforce Integrations page within Calendly, select Install the Calendly package.
  6. Select Install for All Users, and select Install.
  7. You’ll then need to grant 3rd party access. Select Yes, and then select Continue.
  8. Once installation is complete, select Done.
  9. Once the package is installed, make sure to return to Calendly and select Refresh to complete the connection between Calendly and Salesforce.
    Note: If you see an error during installation, you may be using the Group or Professional edition of Salesforce. Your Salesforce edition must be Enterprise or higher to integrate via web service API.
For users currently on v1 of our Salesforce package, check out this article.
What's next?
