Free/busy rules overview
Calendly’s Free/busy rules feature lets you free up more time in your calendar by allowing you to book over specific meetings. This makes it easier to set and manage your availability.
  • Connect your calendar on the Calendar settings page and set it as a Calendar to check for conflicts. Need help? Read more here.
    • The Outlook plug-in is not supported for the free/busy rules feature. You must have an online calendar connection to use this feature.
    • Note: You don't need to use a Calendar to add events to in order to use free/busy rules. But if you do add new meetings to a calendar, make sure your Calendar to add events to is set to be checked for conflicts.
Features
You can use the free/busy rules feature to:
  • Book over events up to 60 days into the future.
  • Book over any personal or Calendly event on your connected online calendar.
    • Note: Once a Group meeting is full (all invitee slots have been scheduled for a specific time slot), you cannot book the same Group meeting over it, even if its name is included as a meeting exception.
Setting up free/busy rules
Set up free/busy rules in your event editor. Here's how:
Set up steps
      1. From your Event types page, select the event type you wish to edit
      2. Select More options at the bottom of the editor.
      3. Expand the Free/busy rules section.
      4. Select + Add meeting exception.
        Add meeting exception free:busy rules.png
      5. Next, using the dropdown menu, select one of the following options:
        • includes
          • This option will search your connected calendar for all event titles that include what you type in the search bar.
        • matches exactly
          • This option will search your connected calendar for event titles that exactly match what you type in the search bar.
      6. Enter your calendar event title into the search bar.
      7. Select Enter on your keyboard to allow those meetings to be booked over for your event type.
        • By selecting Enter, all events listed within the 'x meetings' list can now be scheduled over for this event type.
      8. Select Save changes.
Booking over Calendly meetings
When Free/busy rules are set up, you can also book over Calendly meetings. When you do, you’ll get a notification in your 'New Event' email.
Select the 'View in Calendly' link to be taken to your Meetings page. There, you can reschedule the Calendly meeting if desired.
FAQ's
What events can be booked over?
With our free/busy rules feature, you can book over the following events:
  • Calendly meetings on your Calendar(s) to check for conflicts
    • Outlook plug-in connections are not supported for free/busy rules. You must be using an online calendar connection to use this feature.
  • Connected calendar events
    • Any external event on your connected calendar
    • Focus time blocks on your connected calendar
    • Breaks within your connected calendar
Will booking over another Calendly scheduled event cancel it?
No. After booking over a Calendly-scheduled meeting, you’ll get a notification about any conflicting events.
You can then choose to reschedule or keep the conflicting meeting.
How will I know if my event is set up to book over meetings?
To see if your event is set up to book over meetings:
    1. From your home page, select the event type you wish to check.
    4. Review what (if any) calendar event titles are able to be booked over.
Why can't I see my Calendly-booked meeting under meeting exceptions?
The book over meetings function uses your Calendars to check for conflicts to find conflicts. Keep in mind that Outlook plug-in connections are not supported for free/busy rules. You must be using an online calendar connection to use this feature.
If your Calendly-booked meeting was not added to a Calendar to check for conflicts, or your event type title is not included in the calendar event title, it will not appear as an available meeting exception.
To fix this:
  1. Go to your calendar settings.
  2. Make sure your Calendar to add events to is also selected as a Calendar to check for conflicts.
  3. If you're using calendar invitations as your event type notification method, check that the event type title is included in the calendar invitation title
    • To change your notification type from calendar invitations to email confirmations, check out this article
