How to customize your scheduling page links
You can change the link (URL) to your main scheduling page and the link to event-specific scheduling pages.
Change the link to your main scheduling page
Note: when you change this link, previously-shared links no longer work and will need to be shared or embedded again.
  1. At the upper right side of any Calendly page, select your account drop down menu, then select My Link.
  2. Change your link.
  3. Click Save Changes.
Change the link for an event-specific scheduling page
Note: when you change a link, previously-shared links no longer work and will need to be shared or embedded again.
  1. On the Event Types tab of your Home page, select the event type you wish to edit.
  2. Select More options at the bottom of the event type editor.
  3. Expand the Booking page options section and edit your event 'slug'.
  4. Click Save changes.
Important Note
Shared event type URL's will not be able to be edited by following the steps above. The shared event type URL inherits event name changes with the event name. Changing the event name will not break this link.
Ex. /d/js9/jnd/15-minute-meeting. The bolded section will change however, the unbolded section at the beginning will remain the same.
