Calendly's invitee question features help you collect the right information from attendees. Whether you’re meeting one-on-one or hosting a larger event, you can customize your questions to save time and improve the experience for everyone.
This guide shows you how to use these features to make scheduling faster and more helpful.
Invitee name and email
By default, invitees must enter their name and email address to book with you.
You can choose how the name field appears:
- One field: Name
- Two fields: First Name, Last Name
To change the name fields:
- Go to the Scheduling page and locate your event type.
- Open the
three dots menu and select Edit.
- Select More options at the bottom.
- Expand the Invitee form section.
- Under Invitee details, choose your preferred name format.
- Select Save changes.
Autofill name and email from past bookings
You can let Calendly remember an invitee’s info and autofill it the next time they book. This includes name, email, and phone number (for text reminders).
By default, this is turned off.
To turn it on:
- Open the
- Check the box for Autofill Invitee Name, Email, and Text Reminder Phone Number (when applicable) from prior bookings.
Collect phone numbers
Add a Phone number invitee question to your booking form to capture invitee contact details. This adds a phone field to your booking page.
If you’re hosting a phone call meeting, you can set your meeting location to Phone call so invitees are prompted to enter their number automatically.
Add guests to the meeting
Invitees can add up to 10 guests when booking. Guests get a meeting invite, and you’ll see all guest names on your Meetings page. This feature is not available for group events.
Guest invitations are turned on by default.
To turn them off:
- Open the
- Toggle Invitee guests off.
