How to schedule with conference rooms
Looking to use a conference room to schedule meetings in Calendly? You have a few easy options, depending on how you manage your rooms. This guide covers how to set up conference rooms as event locations using three methods.
Option 1: Using a Collective event type
A Collective event type lets Calendly check everyone’s availability, including your conference room, before scheduling. This helps prevent double-booking.
  1. From the Admin center, add each conference room as a user in your Calendly organization.
    • Each room needs a unique login email address.
  2. Go to your home page and select + Create.
  3. Select More ways to meet, then choose Collective.
  4. Add the host(s): include both the conference room and the team member.
  5. Finish setting up the event type. (See: How to customize your event types.)
Each room added as a user takes up a paid seat.
Option 2: Using a sub-calendar and Zapier
This method works well if you're managing one conference room or shared meeting space.
  1. Create a new "sub-calendar" in your connected calendar for the room
  2. Share the calendar with anyone who will use the conference room.
  3. Use Calendly's Zapier integration to send Calendly meetings to the conference room calendar.
  4. Optional: Set Calendly to check this sub-calendar for conflicts. This will help prevent double bookings.
Option 3: Manually add a conference room to meetings
Use this method if you prefer to set the room yourself each time you book a meeting.
  1. After booking a meeting, open your personal calendar.
  2. Update the location to include the conference room.
This works best for smaller teams or rooms with low booking activity. For higher traffic, consider the collective or sub-calendar methods above to prevent double-booking.
