How to sync Calendly links to Salesforce
Calendly syncs profile and managed event links to Salesforce. This sync enables Salesforce automations and email templates to use merge fields with Calendly links.
How it works
By default, Calendly creates a CalendlyLink record in Salesforce each time a users link is sent. During the next hourly sync, Calendly updates this record if needed.
When a CalendlyLink record is created or updated for a profile link, it triggers the MapCalendlyLinkTemplate flow. This flow matches users by email between Calendly and Salesforce. If it finds a match, it adds the link to the Calendly Link field on the user's record.
You can also customize this flow to sync managed event links. For more details on customizing the flow, check the Help Center article: How to update Salesforce users with managed event links.
NOTE: The Calendly Link field is a text field and the value of the link includes the protocol (https://).
Setting up Calendly link sync to Salesforce
Note: Syncing Calendly links to Salesforce functionality is included in package version 2.3 or higher. If you are unsure of what version you currently use, visit your Salesforce integrations page to confirm your version.
Setup steps
  1. Follow the setup instructions for the version 2.3 Salesforce package or higher.
  2. Create a copy of the MapUserCalendlyLinkTemplate flow template and set the copy to active.
    1. From your Salesforce Flows list, select the MapUserCalendlyLinkTemplate flow template.
    2. Select Save As in the top right-hand corner.
    3. Name the flow by creating a Flow Label
    4. Select Save
    5. Navigate back to the Salesforce Flows list.
    6. Select the newly saved/created flow.
    7. Activate the flow by selecting Activate in the top-right hand corner.
  3. Go to the Salesforce integrations page and select the Sync button to trigger the new active flow.
Syncing
Calendly will sync all profile and managed event links for all of the users in the organization either:
Note: When there is a sync in-progress, the Sync button is disabled to prevent disruption in the syncing process.
