Calendly scheduling notifications
When someone schedules a meeting with you, Calendly sends the details to both you and your invitee. There are two types of notifications:
  • Calendar invitation (most common)
  • Email confirmation
Use the tables below to compare them and choose what works best for you.
Looking for reminders, follow-ups, text alerts, or Workflows? Learn more here.
Compare notification types
How each one works
  Calendar invitation Email confirmation
What happens Your calendar creates the event and adds your invitee as a guest.  Calendly sends an .ics file to you.
What your invitee gets A calendar invite from your calendar.  An email with an event file they can add to their calendar.
Email addresses used
Who sends the notification Comes from your connected calendar account. Sent from notifications@calendly.com.
Who replies go to Replies go to your calendar email. Replies go to your Calendly login email, unless you set a no-reply address.
How updates are handled
If you need to change details like time or location, only calendar invitations send updates to your invitee.
Will invitees see updates? Yes. They’re added as event guests. No. They only receive a static file.
How titles are customized
Can I customize my calendar event title? Yes. Title can be customized for the host and invitee's calendar event. An event is added to the host’s calendar. The attached ICS file cannot be customized.
Which notification type should you use?
Use calendar invitations when:
  • You use Google, Office 365, Outlook.com, or Exchange calendars.
  • You need to make event changes and want invitees to get updates.
  • You want the invite to come from your calendar, not Calendly.
Note: For Collective meetings, the calendar event is added to one team member’s calendar, and other members are added as guests.
Use email confirmations when:
  • You use the Outlook plug-iniCloud, or no calendar.
  • You want to use a no-reply address to hide your email.
  • You’re hosting a group event (these use email confirmations by default).
  • You wish to include hyperlinks as these are not available for calendar invitations. Note: If you wish to include links in calendar invitations, you must paste the full URL.
Change your notification type
Calendly automatically picks the notification type based on your calendar or event type. Most of the time, there’s no need to change it. But if you want to switch, follow the steps below.
Switch to calendar invitations
  1. Go to the Scheduling page and locate your event type.
  2. Open the three-dots-icon.pngthree dots menu and select Edit.
  3. Select More options at the bottom.
  4. Open the Notifications and workflows section.
  5. Next to Email confirmation, select the Three vertical dots.png three dots, then Edit.
  6. If it says Calendar invitation, you’re already set.
  7. If not, select Switch to calendar invitation at the top.
  8. Select Save and close.
You can’t switch to calendar invitations if you:
  • Use group events
  • Are using iCloud or the Outlook plug-in
  • Don’t have a calendar connected
Switch to email confirmations
  5. Next to Calendar invitation, select the Three vertical dots.png three dots, then Edit.
  6. If it says Email confirmation, you’re already set.
  7. If not, select Switch to email confirmation at the top.
FAQ
Can I turn off email notifications or stop receiving emails every time someone books with me?
At this time, you cannot turn off these email notifications. If you want to reduce or stop receiving notifications, you may consider managing your email filters outside of Calendly.
My invitees are not receiving the email confirming their event with me. How can I make sure they get these emails?
First, you will need to identify whether you are using Calendar Invitations or Email Confirmations
If your event uses Calendar Invitations
When using Calendar Invitations as the notification method for your event, Calendly is not sending those invitations to your invitees. Instead, we are prompting your connected calendar to send these invites. To further troubleshooting, we recommend reaching out to your IT team or email provider for assistance.
If your event uses Email Confirmations
Please contact Customer Support and we will be happy to review your logs.
Can I send booking confirmations from a different email address than my profile email?
Yes. You can do this by using Calendar Invitations as your scheduling notification. This allows you to login with one email and notify your invitees of their booking with you with the email address associated with the calendar you add new Calendly events to.
Follow these steps:
Step 1:
Switch your event type to use Calendar Invitations (see “Switch to calendar invitations” above). This ensures notifications are sent through your connected calendar provider.
Step 2:
Connect the calendar account that uses your preferred sending email address. You can follow the steps in the Connect your calendar to Calendly Help Center article.
Step 3:
Schedule a test booking to confirm the calendar invitation is sent from your connected calendar’s email address.
Do hosts receive booking notifications?
Yes. When someone schedules a meeting, the event host automatically receives a booking notification email from notifications@calendly.com.
This default host notification:
  • Confirms the meeting details
  • Is sent in addition to any calendar event created
  • Cannot be turned off
If you're using Calendar Invitations, your connected calendar will also create the event on your calendar.
If you're using Email Confirmations, the invitee receives an .ics file, but hosts still receive the default booking notification from Calendly.
What’s next?
