How to automatically categorize Calendly events in Salesforce
You can set up your Salesforce flow to automatically categorize meetings scheduled through Calendly. This helps with reporting by sorting events by department, goal, or meeting type (like customer engagement or onboarding).
How it works
Salesforce can use your Calendly link (URL slug) to assign categories. The slug is the last part of your Calendly link. For example, in calendly.com/acmesales/pricing-review, the slug is pricing-review.
When you use slugs in your flow, Salesforce can set values like Meeting Type and Meeting Subtype.
Map Salesforce fields based on your Calendly link
In the following steps, we'll categorize meetings by Meeting Type and Meeting Subtype, as examples. We'll create custom fields for these categories on the Activity object for use as Event records. We'll then assign the URL slug as the value for the Meeting Type and Meeting Subtype fields.
For example:
Calendly event type URL Slug Meeting Type Meeting Subtype
calendly.com/acmesales/pricing-review pricing-review Customer Engagement Customer meeting
calendly.com/acmesales/account-overview account-overview Customer Engagement Customer meeting
calendly.com/acmesales/discovery-call discovery-call Lead Engagement Welcome/kickoff meeting
calendly.com/acmesales/30-minute-demo 30-minute-demo Lead Engagement Demo
Step 1 – Create custom fields
  • Before you begin, be sure your event object has the needed fields created (Meeting Type and Meeting Subtype).
    • Custom fields for Tasks and Events must be created at the Activity level. If you are unsure how to create fields on the event object, you can refer to this Salesforce article.
Step 2 – Open your flow
  1. In Salesforce Setup, search for Flows. Select Flows.
    • If you haven't customized the CreateEventTemplate before, you'll need to create a new flow based on the template. To do so, open the CreateEventTemplate, customize it directly, then Save as. Saving it will create a new flow. You can call the new flow something like "CreateEvent."
    • If you've already customized the CreateEventTemplate flow, then open your customized flow.
Step 3 – Add a Decision element and create Outcomes
  1. From the Toolbox on the left-hand side, drag a Decision element and place it next to the Decision, Do We Have a Record? element.
  2. Set the Label to something like "What event was scheduled?" You can also add details to the Description, if you'd like.
  3. Add an Outcome.
  4. Under Outcome details, set the Label to your Meeting Subtype names, or use a label that helps you identify which event type was scheduled. For example, you could set the label to something like "Onboarding Meeting." Once you add a label, the Outcome API Name will automatically populate.
  5. Add the following conditions:
    Outcome 1:
    Resource = {!$Record.Calendly__EventTypeSlug__c}
    Operator = Equals
    Value = insert your Calendly slug, for example, pricing-review
    Note: See above table for examples of your Calendly slug.
  6. Add an Outcome for each meeting subtype you'd like to use.
Step 4 – Create Resources for Meeting Types and Subtypes
  1. From the Toolbox on the left-hand side, switch to the Manager tools, and select New Resource.
  2. At Resource Type, select Variable.
  3. At API Name, enter Meeting Type.
  4. At Data Type, select Text.
  5. Select Done.
  6. Repeat these steps to create a Resource for Meeting Subtype.
Step 5 – Add Assignment elements
  1. Next to the new Decision element you created in Step 2, add an Assignment element to the right.
  2. At Label, enter a name similar to the corresponding Outcome label you created, such as "Onboarding Kickoff Meeting." The API name will automatically populate.
  3. At Set Variable Values, enter the following:
    Variable = {!MeetingType}
    Operator = Equals
    Value = your_meeting_type_here
  4. Select + Add Assignment
  5. At Set Variable Values enter the following:
    Variable = {!MeetingSubtype}
    Operator = Equals
    Value = your_meeting_subtype_here
  6. Select Done.
  7. Repeat these steps for each Outcome option you created in Step 2.
Step 6 – Map your custom fields
For more details on field mapping, view Choose how to map Calendly data to Salesforce fields.
  1. Select the Create Event element.
  2. Select + Add Field from the bottom of the existing field mappings.
  3. At Field enter Meeting_Type__c referencing your custom field.
  4. At Value enter {!MeetingType} referencing the resource you created in Step 3.
  5. Select + Add Field to add another field mapping.
  6. At Field enter Meeting_Subtype__c referencing your custom field.
  7. At Value enter {!MeetingSubtype} referencing the resource you created in Step 3.
  8. Select Done.
Step 7 – Connect the elements
  1. Connect the Decision element to the Assignment elements and select the matching Outcome.
  2. Connect the Assignment elements to the Create Event element.
  3. Save and Activate the flow.
    Note: If you have not previously made any modifications to the CreateEventTemplate, you may only see the option to Save As. In this case, Save As and give the flow a title. Then, Deactivate the CreateEventTemplate flow.
Final results
When you book a meeting through your Calendly link, you should see the Meeting Type and Subtype (or whichever fields you created) mapped to the Event!
