In order to import a Marketo form into Calendly, you will first need to integrate your Marketo account. To do this, you will need three sets of alpha-numeric codes: your Client ID, your Client Secret, and your Munchkin ID#.
Finding your Client ID and Client Secret
From the Marketo homepage:
- Select the Admin tab.
- Select Integration from the panel on the left side,
- Select Launchpoint. This will open up a window in Marketo called Installed Services.
- Select View Details.
- Copy the Client ID and Client Secret from here!
Finding your Munchkin ID#
The Munchkin ID# can be found under your Marketo Admin panel. Click on Munchkin.
...and copy the account ID.
