Having trouble with 404 errors, server issues, or "Oops! Something went wrong" messages in Calendly? Use this guide to troubleshoot common browser and environment issues that can cause these errors and get back to scheduling smoothly.
Start with these browser troubleshooting steps
Most generic errors in Calendly are caused by cached data or browser configuration conflicts. Try these steps first:
- Clear your browser's cache and cookies.
- Open Calendly in an incognito or private window.
- Retry the action that caused the issue — whether it was saving a Workflow, creating a Contact, or booking a meeting.
- Check that your browser and operating system are up to date.
- If issues persist, test with another browser or device to rule out local issues.
Check for browser extensions or VPNs
Some browser extensions or network configurations can interfere with Calendly:
- Disable browser extensions, especially translation tools and ad blockers. Re-enable them one by one to isolate the cause.
- Turn off any VPNs, particularly NordVPN, which is known to cause issues.
- Try connecting from a different network (e.g., switch from Wi-Fi to a hotspot).
Using Google Chrome?
Chrome’s translation tool may cause issues. Try this:
- Go to
chrome://extensions/and turn off Google Translate. - Go to
chrome://settings/languagesand disable automatic translation. - (Optional) Change your Calendly account language from your Account Settings page.
Specific issues to consider
Issue: Repeated server errors when booking or saving
If you’ve followed the steps above and still see errors:
- You may be running into rate limiting or security throttling — this can happen if you're trying to book several meetings in quick succession.
- Solution: Wait about 60 seconds, then refresh the page and try again.
- For Contact creation errors: the contact may already exist.
- Solution: Search for the contact by email before trying to create a new one.
- For persistent Workflow save issues: the Workflow may be corrupted.
- Solution: Try editing the Workflow slightly or recreating it from scratch.
Issue: Blank page after sign-in or on some Calendly pages
- Test multiple browsers and devices.
- Try connecting from a different network.
- Follow the steps to clear cache and use incognito mode.
- Check for active VPNs or network-level blockers.
Need Support? We’ve got you covered!
Every paid subscription includes Calendly Standard Support. However, only owners and authorized admins from your company can make certain account requests. Login to Calendly and navigate to the Help section where you can:
- Browse our Help Center.
- Join our Calendly Community to search, share, and connect with other Calendly users.
- Chat with us to receive real-time help.
