Calendly uses AI to help you save time and get more value from every meeting. Our AI features reduce manual steps and make it easier to take action—before and after meetings.
With AI at Calendly, you can:
- Turn meeting conversations into clear notes, summaries, and action items
- Get quick answers about your events, availability, and scheduling activity
- Use natural language to ask questions and take action in Calendly
- Reduce time spent searching for event details or updating schedules
- Stay organized with accurate, easy-to-share meeting insights
Some products that use AI at Calendly include:
- Notetaker – Automatically records, summarizes, and highlights key moments from meetings
- AI Assistant – Lets you use conversational prompts to discover meeting, contact, and recap details across Calendly
This page gives an overview of how AI works at Calendly and explains how we protect your data and keep your information private and secure.
Frequently asked questions
Calendly currently uses large language models (LLMs) from OpenAI and may add other vetted providers over time. All providers must follow strict rules on how long data can be stored and how it can be used.
- Calendly Notetaker uses meeting recordings and transcripts to create summaries. In some cases, it may also access your calendar to identify attendees and match speakers to the transcript.
- Calendly AI Assistant reviews your data in the Calendly app to give accurate answers and take actions based on your request.
Yes.
Similar to other cloud software companies, Calendly works with trusted sub-processors to run and support its service. Some of them use AI in their own systems.
For example, Calendly runs on Google Cloud. Google uses AI to help manage its cloud systems, data, and security.
This AI supports the tools that power Calendly. It does not change how your scheduling data is handled.
