As a Calendly owner or admin, you can use these steps to disable or delete your SAML SSO configuration.
- Disable: Turns off SSO and SCIM for all users, but keeps your configuration saved. You can re-enable it at any time
- Delete: Turns off SSO and SCIM and permanently removes your SAML and SCIM configuration. To set it up again, you’ll need to re-enter details from your identity provider.
Disable SAML SSO
- Go to the Admin Center.
- Select Organization Settings.
- Select Single sign-on.
- Under Step 3: Enforce for your organization, toggle off Enforce SAML SSO for my organization. If you’d like to enable SSO again, you can toggle it on.
- Select Yes to confirm.
Delete your SAML SSO configuration
- Select Delete SAML SSO configuration.
After you disable or delete your configuration
When users log in to Calendly again, they'll be prompted to use their original login method (such as Google OAuth). If a member didn’t have a previous login method, they can select send me a recovery email to create a new password and log in.
