How to sign in using single sign-on (SSO)
As a member of an organization that uses single sign-on (SSO), use this procedure to sign in to Calendly using your organization’s SSO credentials.
  1. From calendly.com, select Log In.
  2. Enter your email associated with your organization and select Continue.
  3. Select Log in with single sign-on.
You’ll be redirected to your organization’s identity provider (IdP). Depending on your organization’s IdP, you might have to log in using your IdP credentials. If not, you’ll be redirected to your Calendly home page.
If you are on our Teams plan and would like to add single sign-on (SSO) features to your Calendly account, you can do so from your billing page. The SSO add-on costs $3 per user, per month.
