How to create a contact, opportunity, or other object record in Salesforce
By default, when a new invitee schedules, the Salesforce flow will create a Lead. To create a different object record instead, such as a contact or opportunity, you can edit the flow's Create Records: Create New Lead element.
This guide walks you through changing the flow to create a Contact instead of a Lead. You can also replace this with any other object record of your choice.
Create a contact instead of a lead in Salesforce
Version 2 Version 1.11
  1. In Salesforce Setup, search for Flows.
  2. Select Flows.
    • If you haven't customized the CreateEventTemplate before, you'll need to create a new flow based on the template. To do so, you can open the CreateEventTemplate. Here you can customize it directly then select Save as. Saving it will create a new flow. You can call the new flow something like "CreateEvent."
    • If you've already customized the CreateEventTemplate flow, then open your customized flow.
  3. Select the Create Records: Create New Lead element.
  4. Under Edit Create Records, at Label, enter Create New Contact.
  5. At API Name, update the name to Create_New_Contact.
  6. Under Create a Record of This Object, at Object, enter Contact.
  7. Under Set Field Values for the Contact, map the following Fields to their corresponding Values from Calendly:
    1. For the first field:
      • Set the Field to FirstName.
      • For the Value, select Calendly__CalendlyAction__c
      • Select Invitee First Name.
    2. Select +Add Field. For the second field:
      • Set the Field to LastName.
      • Select Invitee Last Name.
    3. Select +Add Field. For the third field:
      • Set the Field to Email.
      • Select Invitee Email.
    4. Select +Add Field. For the fourth field:
      • Set the Field to OwnerId.
      • For the Value, select OwnerId.
  8. Check the box Manually assign variable.
  9. Under Store Contact ID in Variable, at Variable, select WhoRecordId.
  10. Select Done.
  11. To save the flow, select Save. Select Save As to save the modified version of the flow.
  12. To activate the flow, select Activate. Note: you will also need to deactivate the CreateEventTemplate, so you don’t have duplicate events in Salesforce.
