By default, Calendly’s Salesforce flow creates an event when someone schedules a meeting. But you can change this to also create a task or a case.
Follow these steps to customize your flow in Salesforce.
Create a task or case in Salesforce
Step 1 – Open your flow
- In Salesforce Setup, search for Flows.
- Select Flows from the results.
- If you haven’t edited the CreateEventTemplate before:
- Open the CreateEventTemplate.
- Customize it as needed.
- Select Save As, and give it a name like CreateEvent.
- If you’ve already made changes to the template, open your existing flow.
Step 2 – Add a task or case element
- In the Toolbox on the left, go to Data.
- Drag a Create Records element into the flow. Drop it to the right of the Create Records: Create Event element.
- At Label, type Create Task or Create Case.
- For How to Set the Record Fields, select Use separate resources and literal values.
- At Create a Record of This Object, under Object, enter Task or Case.
- At Set Field Values for the Task, set the field values:
- At Field, enter Subject
- At Value, select Calendly__CalendlyAction__c, then select Event Subject.
- Select + Add Field
- At Value, select WhatID, then select the value WhatRecordID
- At Value, select WhoID, then select the value WhoRecordID
- Check the box for Manually assign variables.
- For Store Task ID in Variable, choose WhoRecordId.
- Select Done.
Step 3 – Connect the steps
- Connect the Create Records: Create Event element to the new Create Task (or Create Case) element.
Step 4 – Save and activate the flow
- Select Save.
- Select Save As to create your new version.
- Select Activate to turn on the new flow.
- Deactivate the CreateEventTemplate flow so it doesn’t run at the same time.
- In Setup, search for and select Flows.
- Under Flows, find the CreateEvent flow and select Open.
- In the Toolbox, go to Data.
- Drag a Create Records element into the flow and drop it next to the Create Event element.
- For How to Set the Record Fields, select Use separate variables, resources, and literal values.
- At Create a Record of This Object under Object, enter Task or Case.
- Set the fields:
- Field: Subject
- Value: {!NewCalendlyAction.EventSubject__c}
- Variable: {!WhoRecordId}
- Select Done.
- Connect the Create Event element to the new Create Task (or Create Case) element.
- Select Save, then Save As.
- Select Activate to turn it on.
