The Calendly mobile app makes it easy to schedule and manage meetings while you're on the go. Whether you're working, running a business, or managing personal tasks, the app helps you stay organized.
Before You Begin
Download the app from the Apple Store or Google Play Store.
What you can do in the app
Share your scheduling links
Quickly send your link through text, email, or a QR code. You can:
- Create one-time links that expire after use
- Customize your default share message
- Set up one-off meetings (iOS only)
- Preview your scheduling page (iOS only)
Manage your availability
Set your hours, add buffers between meetings, and limit how many meetings you take each day. You can also prevent last-minute bookings.
Edit your event types
Change the name, duration, or settings of an event type. You can also clone or hide events.
Manage your meetings
View upcoming meetings in one place. Need to make a change? Cancel or reschedule with just a few taps. You'll also get real-time notifications.
