The features available for One-off meetings vary depending on where you're creating them. Use the table below to compare which settings are supported on the web (including extensions) and on the mobile app.
| Feature/Setting | Web (including extensions) | Mobile |
| Host can create a Collective event by adding multiple hosts | ✔️ | ⛔️ |
| Host can add an additional 9 hosts to a meeting | ✔️ | ⛔️ |
| Host can view their available times based on the schedules they set in their Calendly account | ✔️ | ⛔️ |
| Host can select multiple time slots at once to offer as available | ✔️ | ✔️ |
| Hosts will see an "unavailable" banner over a time slot on the calendar picker page if that time slot is in the past. | ✔️ | ⛔️ |
| Hosts can see their external meetings on the calendar picker page when selecting available times | ✔️ | ✔️ |
| Hosts can set the duration, location, name, and details/agenda of the meeting | ✔️ | ⛔️ Hosts can only set duration and location on mobile. Also, the location field in mobile is only a text field. |
| Hosts can customize the URL of the meeting link before they share it | ✔️ | ⛔️ |
| Hosts can preview the available times that they chose for this event before sharing the event link | ✔️ | ⛔️ |
| Hosts can add the time slots they chose as available for this event directly into an email from the share meeting link page | ✔️ | ✔️ |
| Hosts can select a time slot over existing, non-Calendly events to offer to their invitees. | ✔️ | ✔️ |
| Hosts can select a time slot over a buffer that is caused by an existing Calendly-scheduled event. | ✔️ | ✔️ |
| Hosts will be able to see their time reflected in a 24-hour format if that is what is set up in their Calendly account settings. | ✔️ | ⛔️ This is dictated by the host's device settings for time |
