How to delete a group
When a group is no longer needed, it can be permanently deleted from your organization.
  • Once deleted, a group cannot be recovered.
  • Only owners and admins can delete a group; group admins cannot.
  • Deleting a group does not remove members from your organization.
  • Any Managed Events owned by the group will also be deleted.
Delete a group
  1. Go to the Admin center, then select Groups.
  2. Choose the group you want to delete.
  3. Scroll to the bottom of the page and select Delete group.
  4. Confirm the deletion.
After the group is deleted, you can assign its members to a new group as needed.
