Use Calendly’s Share availability feature to send your scheduling link from your connected Gmail or Outlook account. This helps the email feel more personal and recognizable to invitees. You can also choose to automatically send a reminder email if the invitee hasn’t scheduled in 1, 3, or 7 days.
- You'll need to be on a paid plan.
- Connect the Gmail or Outlook for Workflows integration.
- The automatic reminder email can’t be customized at this time.
Share availability from the Scheduling page
- Go to the Scheduling page in Calendly.
- Find the event type you want to share and hover over it to see more options.
- Select
Share availability to open the email composer.
- In the To field, add your invitee's email address.
- (Optional) Customize the message and turn on the reminder email.
- Select Send to share your availability.
Share availability from the Contacts page
Make sure your contact is already in your list. If they’re not, add them as a contact first.
- Go to the Contacts page in Calendly.
- Find your contact and select
Share availability.
- Choose an event type and select Next.
When you select a contact to share your availability with, that person becomes the main email recipient and can’t be changed. To email someone else, close the draft. Then, select Share availability for the correct contact from the main contacts list.
What to expect after sending the email
When you use Share availability, your email is sent from your connected Gmail or Outlook account and will appear in your Sent folder.
If an invitee replies to your email, their response will go directly to your Gmail or Outlook inbox, not in Calendly.
Once they select a time and book, the meeting will appear in Calendly and on your connected calendar as usual.
