Calendly may charge tax on your subscription based on your location as required by local law. If tax applies in your area, you’ll see it when you buy a paid plan.
If your organization is a business, add your Tax ID and company info on your Billing page. This helps make sure you don’t get charged tax on future invoices. Be sure your address is correct.
How to add or update tax info:
Select Admin Center from the left-side menu.
Under Organizational settings, select Billing.
Under Tax Information, select Add information or Edit information.
Enter or update your tax details.
Select Add information or Save changes.
