Calendly + Zapier
What is Zapier?
Zapier allows you to connect your Calendly account with hundreds of apps, including Google Apps, RingCentral, Redtail CRM, and more.
Ways to use Zapier
You can create zaps to automate post-booking tasks and customize your scheduling experience.
Search Zapier's Calendly Integrations for a full list of apps that work with Calendly, then check the list of actions for a good match. For ideas, read 8 Calendly and Zapier automations to help you get more done.
When to use Zapier
If you use an app that's key for your scheduling, but it doesn't directly integrate with Calendly, you can connect them using Zapier. To see which apps Calendly integrates with natively, check the Integrations & apps page.
How Zapier works
When someone schedules or cancels a Calendly meeting with you, Zapier triggers an action in your chosen app through OAuth (Open Authorization).
More specifically, you can trigger an action when the following events happen:
  • Invitee Created: Triggers when an invitee schedules a meeting.
  • Invitee Canceled: Triggers when an invitee cancels a meeting.
  • Invitee No Show Created: Triggers when an invitee is marked as a no-show.
  • New Routing Form Submission: Triggers when a routing form is submitted.
With a multi-user account
Zapier decides which Calendly events to trigger based on your Calendly role and the permissions granted during the OAuth process.
Zaps will trigger for the following events and roles:
  • Organization: All scheduled meetings in the Calendly account.
  • Group: All scheduled meetings in the selected group.
  • User: The user's scheduled meetings.
The group subscription scope can only be used with the Invitee Created/Cancelled triggers and will not work with the no-show trigger. You must be a Calendly organization owner or admin in order to use the organization or group scope.
How to connect your Zapier account
Our Zapier integration connects via OAuth for authentication and authorization. For a detailed overview of the attributes, check out Zapier fields and labels.
Step 1 – Connecting Calendly to Zapier
  1. From the Calendly Integrations & apps page, select Zapier
  2. From the Zapier integrations page, select Connect Zapier
  3. You'll be redirected to Zapier and prompted to log in to your account.
  4. Once logged in, you'll be guided to create a new Zap. We'll further discuss this in Step 3 below.
Step 2 – Schedule a test meeting
  1. In Calendly, go to your Home page, locate an event type you'd like to test, and select view booking page.
  2. Fill out the invitee details, and select Schedule Event to provide Zapier with invitee sample data.
Step 3 – Create a zap
  1. From your Zapier account, follow Zapier's instructions to Create a new Zap.
  2. Complete the steps listed below.
How to create a zap
  1. For your Trigger, at App Event, select Calendly.
  2. At Event, select Invitee Created or Invitee Canceled.
  3. At Account, select Sign in to connect Calendly via OAuth.
  4. Zapier will momentarily load, and then redirect you to connect Calendly. Select Connect to Calendly.
  5. From Trigger, under Webhook subscription scope, choose user or organization and select Continue
      • Note: The user subscription scope only triggers webhook for subscribed events that belong to the specific user. The organization subscription scope triggers the webhook for all subscribed events within the organization. You must be a Calendly organization owner or admin in order to use the organization scope.
  6. At Test, select Test trigger.
  7. The invitee data from the test meeting you scheduled in Step 1 will be used for this test.
    • Note: The test invitee data is used to ensure your setup is correct. When using the Invitee Created trigger, Zapier will pull data from the most recent non-canceled meeting. To view a sample of the invitee data Calendly sends over, view the Webhook Payload
Trigger zap for certain conditions
If you have a paid Zapier account, you can add steps to your zap. With multi-step zaps, you can add an action, like filters, to specify the zap for certain people, event types, or details. For more complex conditions, you can also use Paths.
Filters
When you add a filter, your zap will only run if certain conditions are met. For example, you can filter your zap by:
  • Team member: Only continue if John is the team member booked (Image 2).
  • Event type: Only continue if Coffee Chat is the event booked.
  • UTM parameter: Only continue if UTM Source is email.
  • Answers to questions: Only continue if an invitee answers yes or maybe.
Troubleshooting Zapier
Your Zap History contains a log of all your zaps. If your zap isn't working as expected, your Zap History will give you more details as to why a zap failed. If you need help with your zap, contact Zapier support.
